Hoss 350
My GSP, Dutch
\ForumBlue said:Thanks, Big red. Brakes are cheaper than Trannys so I guess I'll leave it alone.
This is not necessarily true. You automatic guys can do this, too, you just need to do it in conjunction with a TC lockup override, which locks your TC when you turn ont he switch. If the TC is locked, you will not hurt anything using an exhaust brake. Even if it isn't locked, and EB doesn't hurt anything, it just doesn't do much, because the unlocked TC doesn't transfer very much braking horsepower to the rear wheels.
It will not hurt your transmission to use an exhaust brake.
What i would do is wire the EBPV as I discussed above, and then run the 12V off the SAME SWITCH to lock the TC. That way, as soon as you turn on your EB, it locks your TC and transfers braking HP to the rear wheels.
