TampaDieselFX4
Ok, I put on a 4" turbo back exhaust and it's leak free until after the Cat area, where you use U bolts. Where the pipes come together, those slits, you can see over time some blk soot around them. Is this normal on aftermarket 4" exhausts? I put the U bolt halfway back/forward on the slits if you can understand that. Am I the only one? Don't get me wrong... the leaks are so small you can't even feel them. just over a few thousand miles you can see the blk streak.
