Hope someone has had this problem before or can explain. I'm getting exhaust smell in the cab that worsens when the defroster/vent is turned on. I'm also completely fogging up the windshield for several seconds when I turn on defroster (long enough to crash into a telephone pole),no I didn't,but I could have! The defroster eventually clears it up, but I think these two problems are related, what do you think?
Thru the years, there have been many Posts about this. So yer Not the first ?
You might check the [clamp] connection between yer Turbo outlet and the Down-pipe.... When the engine is COLD. Tighten it a turn or so.
What Can happen is: When the engine is cold and you start it, if the connection is loose at all, even a little bit, exhaust and it's smell(s) blow by the connection.. migrate up.. and yer AC/Heater intake can suck it up and blow it into the cab. After the engine warms up and the connections swell with heat.. it seals it's self.... No smells.
Mine did that, I did that, it fixed that *
The fogging could be (probably is) caused by the Ambient air temp/humidity levels of the outside air, that's blown thru the defroster vents.. At Start up.. 'til the A/C (dryer air) catches up... Takes a moment or two for that to happen.
Ive learned to live with that
* BUT... The Smell of diesel fuel, at start up, cold or hot, (depending on wind direction) is a strong pungent smell to some. If it "Wafts" over yer truck ? you may still suck it into the cab. Personally, I like it....
