Excursion headlights?
J_F250
SDD Burger Flipper
Monteagle, TN
How would excursion headlights look on my F-250? Anybody got any on theirs? I came across them and since I was having a hard time finding OEM 250/350 and I thought "maybe".
They're much better than the 99-2001 headlamp lenses,I say pick up a set:sweet
J_F250
SDD Burger Flipper
Monteagle, TN
They should fit. They are exactly the same.
They are not exactly the same. They are the same size but they look like they have a separate "low beam and high beam"? parking light, fog light, something
Somebody tell me what the bottom clear light is?
Scooter
Mesa, Arizona
Are you talking about the 05 and up lights? My 01 excursion has the same lights as my 2000 pickup. My 06 pu is totally different.
architect-builder
Jerome, Idaho
Is it a one piece assembly or is it still two pieces. If it is one piece you have a 2005 Excursion/Superduty assembly, It is still the same for both rigs in 2005, headlight on top, running lights/turns signals on bottom. They will require some different fastening methods than what you have unless you change out the whole front end to the 2005-07. Many have done just the headlight conversion so it is not that difficult.
If it still two pieces, you are talking about a 2002-2004 headlight assembly. This was when they changed to the crystal clear headlight assembly with the clear corners.
Top, headlight, bottom, running light & turn signal. And, they are the same on the Excursions and Superduties, they will fit fine.
Barrett
architect-builder
Jerome, Idaho
Yeah they look one piece look better than mine fo sho!
Those are the 05's (and 06, 07's). You will need to get the pigtails for the 9008 Bulbs (from your 9007's) or you can get the upgrade harness from GOS like I did. They do attach differently but it's been done. You will like them much better.
Barrett
Here is the link for the harness.
