Error Code 0733/0733 with brand new tranny
probablecause
1999 F350 Superduty TD, Had what I thought was the transmission going out on the way back from a trip (truck has original trans @ 150k miles). Truck would not shift out of second gear. By the time I got home. Reverse was acting up. Took it into Ford for a rebuild (New Torque converter and valve body also).
New Tranny: Put on 200 miles with no load and it ran great. After my last trip, and about 20 miles of load (14k 5th wheel), I cam off the freeway but when I started from a stop, it would not shift out of 2nd again. Got to where I was going via surface streets and watched the trans temp gauge. All is fine. To make a long story short, something burned up again in the trans and there were the error codes of 0732 & 0733. I trust the rebuild but since this was the same thing happening before, what do these error codes mean and how are the remedied?
probablecause, Sorry to hear about your transmission going out for the 2nd time. Welcome to SSD.com Hope you have found a home to come to and talk about Superduty PowerStrokes. Tell us more about your truck and also post where you are from.
Someone will be along shortly to let you know about your codes.
whatabudro
Launched
Welcome to the site:sweet
P0730 Incorrect Gear Ratio
P0731 Gear I Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
Beats me, but if Ford just did your tranny they should be standing behind it. Please let us know how it turns out
Tbar
SDD STAFF/Moderator
200 miles.................... ???
Wonder if they changed out the tranny cooler and flushed the lines...............I'm sure they would have.
Tbar
probablecause
I hope they do to. They will, they have no choice. The told me I needed a new transmission for my problem (and I probably did at 150k miles) but it appears to be electrical.
FlorWhitfe
