Engine ticking
IDSTROKER
Blackfoot ID
Blackfoot ID
I have a ticking sound comming from the driver side back of head sounds like a valve tick i have no exhaust leaks or nothing still runs good had for a little while but starting to bug me now any help :dunno
Tbar
SDD STAFF/Moderator
Try a diesel fuel additive that lubricates the injectors before throwing parts at it.
2-cycle motor oil, Stanadyne......even bio-diesel will make the engine quiter.
Tbar
IDSTROKER
Blackfoot ID
Blackfoot ID
i Have been running 2 cycle oil for a long while now it help but not much and tried a few other thing to but not working i just hoping it not needing head work @ 148,000 miles
treyloco
Metairie/Louisiana
I had a '99 f250 w/ a ticking noise and started using Lucas injector cleaner. After a while it started to go away until it drowned in 10' of water.
You might wana consider The HPX line install. It's a High pressure oil line that goes across, between the Heads/oil rails, equalizing the oil pressure that "Pops" yer injectors.
:dunno
texasstroker
Cottondale,Texas,USA
I have the same noise on my 2001 that has only 55,000 miles on it. B20 seemed to quite things down a lot but we can no longer get it around here. I use Power Service Diesel Kleen and it helps a little. Dont you just love this ULSD fuel. If you find out it is anything other than fuel please post it. I was a little concerned when I first noticed it because the original owner used a K&N drop in filter from 5K miles until when I bought the truck at 41K and it was leaking some dirt by the filter.
Many of us are using the 2 cycle oil from Wally World with good results :dunno 16 oz to 16 gallons. (Blue bottle, with TCW3 in it)
Puts a little lubrisity back into the ULSC # 2.
FlorWhitfe
