rammertide07
Nope.
The fuel system, by design, will eventually purge any air.. from things like.. a filter change.. or some work fuel line work etc.. BUT.. as long as there are fittings like, the fuel pump inlet fitting.. the mixing valve set up in the fuel tank.. yer guna have [constant] (possible) sources for air to be SUCKED into the system.... whenever the key is on, engine is running.
Did you read up, in the WIKI/Search areas about the fixes ??
Yes I have, but I'm afraid I'll get in the middle of doing either (especially the hutch mod) mod and find myself not having the know-how on finishing the mods or putting it back the way it was. Not to mention it rains constantly here in LA and I have no dry shelter to work in. I would like to have someone with more mechanical experience with me to help out...unfortunately my dad is no where around.
I thought about something and was wanting to ask if it would work....
Take an old fuel filter lid and tap it with a quick connect for an air line and put a gauge on it....screw it down onto the fuel filter housing with the gasket and charge the housing and see if the pressure drops indicating an air leak. I figured that the fuel on the inkector side is at a dead end and no air would get to the injectors....and it might push the fuel back into the tank if its possible. Any thoughts?? I'm sure its not a good idea but I've never heard of anyone mention it.
Also, when I let my truck prime the fuel filter bowl, I went back out and flipped the yellow lever to make sure it did have fuel back in the bowl (I'm paranoid) and it came out with force. If the fuel system had a way for air to get in, would the bowl eventually loose pressure...over time? Or would it loose pressure anyways regardless of an air leak??
I'm sorry for all the questions...I'm just not familiar with the fuel system on these trucks. Thanks for all the help
And what happened to the pics on the FPR shimming??
