Engine oil question...
mschn99 said:
:roflmao alright...i thought i had heard everything trying to sell synthetic oil....but you honestly are saying it "fixed" your oil leaks......now ive heard them all......:roflmao
Actually Marc, if you re-read Rich's post you'll see that he STOPED using synthetic oil in the trucks and oil leakage slowed down and milage increased. I dont think he was claiming that synthetic "fixed" anything.:sweet
Wood County Tx
anything is possible
if it came from the day one with synthetic in it and was leaking...
we have no way to see the past maintenance or care and feeding, :dunno
so it could be simply the rotellas extra detergant and ash dispersants had some reaction with the sludge in teh engine and filled in the leaks,:dunno
probably accounted for the mpg increas as well ....less frictional loss from sludge???
cant really say without seeing the engines insides and maint records,..
if its a fleet truck chances are its driven like a rental
No curb to tall, no hole to deep, I pray this rental car I shall not keep.
i was merely commenting on those engines with bad prevent maint. that developed leaks when shifted to syn,
STROKIN96
Crumm said:
Mobil 1 Turbo Diesel Truck 5W-40
Mobil 1 0W-40
5W-40 "Meets diesel engine requirements of Cummins, Powerstroke, Duramax and Navistar."
0w-40 "the viscosity recommended by many European car builders"
Think I will stick with 5w-40 :sweet
I understand that there is a diffence b/t the two but if you look at the API SERVICE SEAL(the "S" means spark ignition and the "C" mean compression igntion...the letters after that are the "years" for a lack of a better work that the oil is suitable for....the closer to the end of the alphabet the better the oil meets standards.....)at the back of all oil it will show the rating and what it can be used for....I wanted to us it b/c I have an abundance in my garage and i thought that i could get rid of it if I used it in my truck.......
Carl
94f450sd
certified nutjob
plymouth,ma
the international has the oil changed every 4,000 miles.the GMC is done every 2500 miles do to the fact that the driver puts about 700 miles a week on it and the company can not afford that truck being down longer than an oil change takes.these trucks are very well maintained by me.if one of them has a problem or needs something repaired they come straight to me,no questions asked.thecompany owner doesnt even know when these trucks are comeing to me,he just writes me a check at the end of theweek.
94f450sd
certified nutjob
plymouth,ma
heres some info from steve baz's site
Engine Oil Requirements
The most common problem with Ford's 7.3 Direct Injection Turbo diesel is related to engine oil change interval and type of oil being used. It is critical for proper engine operation that the customer or technician servicing the vehicle check that the correct oil is being used. This engine uses a high-pressure oil pump to operate the fuel injectors.
Typical system pressures are 500 psi at idle, 1200 at 3300 rpm in neutral, and 3600 psi at full load acceleration. Oil for the PowerStroke requires an anti-foaming agent to prevent the oil from aerating, which would result in poor fuel injector spray patterns and reduced power. Depending on vehicle usage, the anti-foaming agents are depleted in 3000-5000 miles.
The only oil recommended for the PowerStroke by Ford is Motorcraft Super Duty 15W40, 10W30. Each of these has the proper additives in them for use in a diesel engine including the anti-foaming agents. The 15W40 is recommended for normal climates, the 10W30 for temperatures below 20 degrees Fahrenheit. For temperatures below -10 degrees, 5W-30 is recommended. There are other oils, however, that do meet all the requirements for use in the PowerStroke. The specifications the owner needs to look for on the label are the API rating of CF-4/SH or CG-4/SH or higher. Some other oils with the correct ratings are:
Penzoil Long-Life 15W40
Shell Rotella-T 15W40
Chevron Delo 400 15W40, 10W30
Mobil Delvac 1300 Super 15W40
Castrol Heavy-Duty 15W40
Valvoline All-Fleet Plus or Cummins Premium Blue:
Union 76 Guardol QLT 15W40
Wal-Mart's Tech 2000 Universal 15W40
Texaco Ursa Super Plus 15W40, 10W30
Quaker State FCI Universal 15W40, 10W30
Quaker State FCI HDX Plus 15W40
Kendall Super-D 3 15W40, 10W30
Kendall SHP Diesel 15W40
For those of you wishing to use synthetic oil, the only ones I have seen with the correct specs for the PowerStroke engine are:
Motorcraft Super All Season 0W-30 Semi Synthetic
Amsoil Series 3000 Synthetic 5W30 Heavy Duty Diesel Oil
Amsoil 15W40 Synthetic Heavy Duty Diesel and Marine Oil
Amsoil 10W-40 and 20W-50 Synthetic High Performance Motor Oil
Amsoil 15W40 Semi-Synthetic Gasoline and Diesel Oil
Mobil Delvac 1 High-Performance Synthetic, Heavy Duty Diesel Engine Oil 5W40
Quaker State 4X4 15W40 Synthetic Blend
Shell Rotella SB (synthetic blend)
Royal Purple Synthetic 10W-30 and 15W-40 EO-L 5W-30, 10W-30, 20W50
Schaeffer's Supreme 7000 Synthetic Blend 15W-40
If these are unavailable you can use a multi-grade synthetic designated CF for use in diesel engines along with an anti-foaming additive. Some synthetic oils with this rating are:
Mobil 1
Castrol Syntec
Valvoline SynPower
Quaker State Syncron Ultra Performance
Recommended anti-foaming additives are Fleetrite with the Navistar P/N CH1824392 or Lubrizol 888. These are primarily used to counter the effects of silicone sealers on the anti-foaming agents in the oil or if the agents become depleted from use providing the oil is still serviceable and uncontaminated. An anti-foaming additive could also be used between oil changes if an oil-related poor running condition is suspected, especially on a long trip.
Under normal driving conditions the additive could extend the oil change interval to 6000 miles. For vehicles that are used for infrequent towing, using the additive at 3000 miles could extend the oil change interval to no longer than 5000 miles. Vehicles operated in dirty conditions, extreme weather conditions or constantly under heavy loads should stick to the 3000 mile service interval due to the other agents in the oil being depleted, and should only use the anti-foaming additive if performance problems occur between services.
The refill for the crankcase is 14 quarts for 94-97's and 15 quarts for 98.5/99's with filter change. Some early 95 and older engines were equipped with a 12-quart dipstick (Navistar P/N 1820068C1) and need to be filled to just over the word "FULL", or replaced with the correct part (Navistar P/N 1824405C1; Ford P/N F4TZ-6750-E for F-series; F5UZ-6750-A for Econoline). Some later dipstick tubes were not seated properly causing the crankcase to be over-filled in an attempt to bring the level up to the mark. The oil filter for the PowerStroke (Motorcraft P/N FL1995) is longer than that of the previous Ford/Navistar diesel, and the old-style filter should not be used. Due to its seal design, the oil filter should be hand tightened, then turned an additional quarter-turn--or torqued to 20ft/lbs--with the oil filter wrench to prevent leaking.
STROKIN96
Rich,
Great info:thumbs
...That helps out a ton.....
Carl
JOAT
I Found Nemo!
The West Coast
You might want to check with Mobil-1 support and see what they recommend. 0w-40 is a much lighter grade than originally recommended, but depending on the modern additive package, it may still be considered suitable. The biggest issue is the shearing effect of the HPOP and HEUI's, and oil foaming.
FWIW, I currently run Amsoil 5w-30 HDD in mine.
odd oil history,
-Previous owner changed oil at Ford, using about a quart every 2000 when I got it at 250,000 miles
-Switched to Amsoil 15w-40 Diesel and Marine, used a quart about every 3000 for next 40,000 miles
-switched to amsoil 5w-30 HDD, using less than a quart every 5000 miles for 45,000 miles
-changed injector o-rings on one side, now used around a quart since then, 11,000 miles
(oil analysis shows no oil dilution by fuel)
JSPulliam21
Uva Uvam Vivendo Vari Fit
Castalian Springs, TN
Crumm said:
Add "and don't live in a cold climate" to that and I will agree. I run synthetic and change it every 5000 miles. The reason for me using it is 1. dino does not flow well at -40 and 2. the synthetic does! One good side effect is the engine is a little quieter with it.
Back to the original question. "0W-40 Mobile One" I would say no. The Mobil one oil that is the proper rating for our trucks is 5W-40. 0W-40 sounds like oil for a gas rig to me but it may be some sort of multi-use oil?
Thank you Crumm. That was one condition I forgot to include.:sweet
Ricksofla
