devgru2011
I have a 2004 F250, i bought it used last september with 116,700+ miles on it and it is now up 122,000+. Over the winter i've been having a cold starting problem. The starter would turn but it would not ignite. I replaced my icp sensor, did not fix it. Replaced cam sensor, did not fix it. Computer IS all up to date. Glowplugs all checked out ok even replaced one of the harnesses. Problem still exists, but now that the warmer weather is here i really dont have the problem anymore. 2 mechs said that it can be my cam harness or engine harness (i believe the 2 are the same?).
I also have a rear main seal oil leak, nothing major, just notice a small stain a little bigger than a quarter after sitting over night.
Things i plan on doing after starting problem is fixed:
EGR delete
MBRP exhaust
Any ideas that could help with my situation and any suggestions before i make any other modifications? I only have a Banks Ram air installed and thats it. Also, does anyone know of an extended warranty plan that can cover these problems that will not care or notice a cold air intake?
Thanks in advance!
- Tony
EGR delete
MBRP exhaust
Thanks in advance!
- Tony
