Bolt
I am going to put a coolant filter on my 2005 6.0. Am I correct that I do not want to run a filter with SCA's in it? Is the dieselsite setup worth the 120 bucks? How about 80 bucks for the SP Diesel one? Or just piece it together from the parts store?
Where can I find a 203° thermostat? The dieselsite only seems to show them for 7.3's. Is it even a mod worth doing on the 6.0's? Will I need a new housing when I install it?
Is Evans Coolant worth the $$$$, or will I be just fine with a properly serviced gold coolant setup?
