LeeParsons
High tech redneck
Anyone have a link to someplace online that sells electric fan conversions for these trucks?
Thanks,
Lee
Thanks,
Lee
How do you know this? Have you tested them somehow? How can fans designed for low-load 4 and 6-cylinder engines possibly move enough air to keep a 1000 pound medium-duty v-8 diesel cool when it is at 100% load pulling a 10% grade on a 90-degree day?MUDWHISTLE said:But I know they more more then enough air for the 7.3,
Under these conditions, it is probably superior to the belt-driven fan, since it is probably on all the time. However, I just want to make sure that guys that tow big and heavy realize that Taurus fans probably won't get the job done.specially good in slow moving traffic for using the air conditioning. should be affordable too less then a new kit.
Hoss 350 said:How do you know this? Have you tested them somehow?
For a lot of guys, you could run without a fan at all and be fine. The cooling systems on these trucks are designed to cool, and do it very well. The electric fans would be a step up from this.95_stroker said:There's several OBS guys running electrics. JOAT, THE_ALASKAN (drag racing), RickH maybe also. It can be done.
