egt???
innaccurate and nearly meaningless is what you can expect in that location.
put it in the manifold pre-turbo and youll be able to compare it to
everyone else.
ive run the probe in both locations and can tell you the manifold is not
dangerous and its more accurate
Zookie400
I WANNA GO FAST
wallingford, CT
after the turbo you will want to go no higher than 900, and around idle maybe see 200-250ish? (not so sure about the 6.0)
as a somewhat vague and general rule the turbo outlet will be about 300* cooler than the manifold.
the manifold is more accurate, however i wont be drilling mine out because my DP has a bung wlded in already. the manifold is not "dangerous", but i have replaced a few probes on trucks where the tip came off........if your probe is in the manifold and that happens, kiss the turbine goodbye. i havent heard of it happening around this site, but its totally possible.
i think its funny...the guys who are worried about a pyro probe break are the same ones that run sand/dirt passing "performance" air filters
Ironmerganser
Ironmerganser
Omaha, NE
REALLY? The tip coming off? I can't hardly beleive that ISSPRO would tell you to mount it in the manifold if that could happen. And if it is a possibility, wouldn't they put that as a warning in their installation instructions?
I guess anything is possible though. :dunno
Zookie400
I WANNA GO FAST
wallingford, CT
like i said, i havent heard anybody around here have a tip break off in thier manifold OR dp, but i know we replace at least one a month on the class 8 stuff at work.
probably not likely, but dont say it wont happen!
05oneton
i just got my gauges in yesterday and so now that I can monitor my egt, is keeping it under 900 what we should be looking for on a 6.0? cause it wasn't clear from the earlier post.
P.S.-These ISSPRO gauges are sweet looking and even better when the its dark and the lights are on.
TacoCat
