EGT Probe
mustangmuscle
PSL,FL
Installing EGT gauge. Which way is better? I have the option to drill and tap or to use the clamp on method. Thanks for your input
I drilled my drivers side manifold. It is easy and should be no sweat. Then I tapped the manifold and used screw in components.
rammertide07
Rogersvilles, AL
I drilled my driver side manifold (with the truck running) and tapped it. Tap and clamp might not hurt. But mine has been in there for the past 4 months with no issues
