EGR Valve
chrispugs1967
chrispugs
north haven,ct
So i get a check engine light and i pull code P0401(exhaust gas recirculation flow insufficient) so it this just telling me the Valve may be bad or dirty or is it something else because of the insufficient flow? I did give it a good cleaning about 5 months ago or 2500 miles ago. Ohh it's a 03 6.0.
atk
Moderator
simcoe, ontario, canada
possible could be the egr is bad and not is opening up....
when you had the valve out did you clean down in the area where the egr sits. there are ports there that could plug up, resulting in insufficient flow...hope this helps
TacoCat
