remove the two bolts, turn the egr valve 1/4 turn, loop some wire thru
the bolt hole ears and pull up...
i connect the loop of wire together and then use a long pry bar (some
use broom handles)...i thread the bar thru the loop of wire and
leverage one end on something (that wont break)...with a little pressure
(UP) on the bar & loop of wire the egr should come out pretty easily.
you should becareful not to get any soot/dirt or liquid cleaner in the
VENT HOLES on the bottom of the motor/actuator...i tape the base of
mine off.
change the o-rings & graphite base gasket (7 bucks for the 2 o-rings &
gasket kit) Ford part number 3C3Z-9P455-AB
FDDTS - 6.0L EGR Valve Cleaning
