W4RLR
High Tech Hillbilly
A problem cropped up last Thanksgiving on a trip to Texas. The truck started running like it was pulling an anchor, when I was only pulling my fiver. I checked everything out in Houston, found I was low on coolant. Filled up the degas bottle, all was well to San Antonio and back to Florida. I was at 97,000 miles then.
I had the coolant replaced at 100,000 miles.
I'm now approaching 103,000 miles. I pulled the fiver to the RV shop for a new awning install. On the way back home, I thought I smelled hot coolant, so I stopped, opened up the hood and found the degas bottle was dry again. Filled up the degas bottle and the smell went away. I haven't noticed any white smoke at all.
I'm installing the coolant filter I ordered from DieselSite tomorrow. Anything I should be looking for while I'm under the hood? If the EGR is going south, should I replace it with a BulletProof Diesel unit or delete it and add a tuner? Does anyone know of a good shop within 250 miles of Pensacola that does good work? While my dealership is listed as a BulletProof distributor (surprised me too!) I don't want to take out a second mortgage to pay for the install if you catch my drift.
Thanks to all.
Thanks to all.
