EGR Delete Pipe....
i bought one, but it broke within a months time. i saw a 4lb. boost lost, and it would still puke coolant out.
i sent it back, and the vendor was very understanding, and i used the credit towards a custom SCT tuner.
i saved the OEM up-pipe and had it re-installed.
PainTrain
Williamsport Maryland
Was this from the Elite Diesel site or from somewhere else? And you lost 4lbs of boot? Why would that be when the pipe opens up the flow?
yes, it was from elite diesel, you have to unplug the EGR valve, if you dont, you will see about a 10lb loss. it probably would have worked better if i had the SCT to work with it.
i really dont know why it broke, and elite couldn't figure it out either.
but the SCT tuner i got coming will delete the EGR valve all together thru the PCM. :thumbs
TacoCat
