well boys i wont bore you with the details, but i did an EGR delete, had some gooey paste in the intake but i cleaned it okay, oil cooler was plugging up.
Here is what i know, don't do this job with a hangover the tear down will go very poorly take my word for it. Don't brake your map sensor off it will cost you $114.00. Don't forget to get the egr delete kit with the new gasket for the intake (big O ring) otherwise you get to buy it from the dealer for $74.00 and all you want is the "O" ring.
The question: I can't get over 20psi on boost, anybody have any thoughts why. I did leave the EGR valve plugged in and bolted in the manifold instead of a block off plate need it for visual on smog and didn't know what to do with the wires anyway so i just plugged them back in.
Job was a little tough but so is life.
