Question EGR cooler issues
DieselPower
Diesel Lover
Memphis, TN
Has anyone dealt with EGR cooler problems? I was told by the dealer that I am losing coolant through the EGR cooler. They want $2,500 to fix it. Has anyone hear about the EGR DELETE kit? Would it be OK to use this kit, or just replace the EGR cooler? Thanks for your comments.
2 Stroker
Warren/Oregon
Well are you having white smoke out the tailpipe this is the first sign then low on coolant a coolant filter is needed to remove the casting sand then do a coolant flush but you should have gauges to tell the temp spread between ECT-EOT max is 15* i think 10* your oil cooler is getting plugged then the egr cooler goes BOTH must be replaced.
BulletProof EGR Coolers
Just remember if your temp spread is greater than 10* your coolers may be getting plugged and it is a ticking time bomb.:eek:
This should help you understand the reason to ditch the Gold junk it can't take the heat. Gauges are a must to do this need to know EOT-ECT
Replaced oil cooler still difference in temps - Page 21 - Ford Powerstroke Diesel Forum
Flushing and cleaning the 6.0
Restore is for cleaning out any silicate goo. VC-9 is for cleaning out iron and scale. Restore Plus is the same as VC-9 and cheaper.
To flush drain the coolant by removing the lower radiator hose from the radiator, and removing the drain plug from the driver side of the block. There is a drain plug on the passenger side also but you have to remove the starter to get to it. I don't bother with that one.
I also highly recommend you pull the thermostat out on your first drain and put the housing back without the thermostat. It only takes about 10 minutes and will save you 2.5 hrs or so in doing this whole procedure.
Ok now put the lower hose back on and the drain plug back in the block if you removed it. This is the procedure you will use each time to drain the system, except you will not touch the thermostat again until you're finished the whole procedure. Make sure that you set your heater to high while doing this to flush out the heater core as well.
Fill the cooling system with distilled water, start the truck and let the water circulate for 5 minutes. (if you did not remove the thermostat you must run the truck until the thermostat opens + 5 minutes to circulate. This takes 15 to 20 minutes each cycle and is why you should just remove the thermostat) Stop the engine. Drain the system and repeat the flush.
Now add at least 1/2 gallon of Restore and fill with distilled water. I used cardboard in front of the radiator because you have to get to 185* 190* for these products to work. Drive truck or run on high idle for 60-90 minutes just before you get back from your drive remove the cardboard this will help in the cool down same on the Restore+ flush. Drain and flush 3 or 4 times. or tell clean
Add 2qts VC-9 or 1/2gal of Restore Plus, top with distilled water, and drive the truck or run on high idle for 60-90 minutes. Now drain and flush until flush water comes out clear and clean. When you get clean flush water, flush 3 more times using distilled water while draining the block.
After your final distilled water drain it is time to put the thermostat back in. I recommend you install a new thermostat at this point. They are only $20 or so and it is good maintenance procedure to do so. Fill with 3.5 or 4 gals of ELC concentrated coolant and top off with distilled water. Drive the truck or let run for a while topping off with distilled water. Check the truck over the next few days and top up as required while any air left in the system works its way out.
Keep some 50/50 ELC on hand to use to top off the cooling system from here out and you are good to go.
new t/stat from Ford it should all come together (housing-t/stat-o-ring) in a box. The part number is RT-1169
Here is the Restore Product from Cummins dealer
http://www.fleetguard.com/pdfs/produ...LI33024-GB.pdf
I used 48 gallons of distilled water 1/4 tank of fuel and 12.5hrs of my time
2 stroker
HeavyAssault
King William, VA
Deleting the EGR system can be done cheaper if you want to do the work. With everything you need to remove there are several things that can be upgraded at the same time. How are your mechanical skills??
DieselPower
Diesel Lover
Memphis, TN
I can do it. What upgrades are you talking about?
DieselPower
Diesel Lover
Memphis, TN
Thanks for your comments. I am still not sure if I should change the EGR cooler (and oil cooler), or do the EGR delete kit. I don't want to cause any issue down the road. (in the long run)
HeavyAssault
King William, VA
Since replacing the oil cooler and deleting the EGR cooler requires removing most of the top side bolted stuff consider the following as "updates/upgrades". Without knowing what year your truck is apply the following:
Blue fuel pressure spring (Ford or International)
6.4L fuel banjo bolts
Turbo oil feed and oil drain lines
Coolant filter kit
Oil by-pass filter kit
Use an ELC for the coolant refill
Since it seems as you need to kill the EGR, get a delete kit and make it happen soon. If the cooler ruptures even more there is a chance of hydrolocking the motor.
scottu5
