On going in the Powerstroke Surgical Ward and So are the Days of Our Lives
Welll tonight I decided I would try to determine if I needed to do head gaskets or if mine were OK. I believe that my head gaskets are ok. I've never ran a tuner, never even been a goose neck or 5er hitch mounted in the truck and the only pulling I have done is my 16 ft trailer and farm tractor about 15 miles at a time. That may be why I'm all chocked full of carbon gunk buildup.Look at the pictures below.
The yellow coolant is just that, pure and yellow coolant. No oil etc.... There is an oil leak on top near the back of the engine next to the firewall. See Pictures.
"Most owners who discover oil under their Super Dutys especially 2003 models often assume the worst, when in reality it's a failed injection control pressure sensor (ICP), which is located under the turbo at the rear of the engine valley." I believe it is the ICP sensor or leaking valve covers as the oil comes from above the head gasket line. Tell me if you disagree on this???? I believe I should see if it is the ICP sensor or valve cover gaskets while I've got it stripped down this far. I believe there are only a couple of dozen more bolts to remove to get the covers off. I have also attached a picture of the EGR valve being cleaned as it sets in a glass of seafoam fuel injector / carbon cleaner. Rotate it right 90 degrees as it is not really sitting on the wall. It came out nice and clean like a new one would look. Picked up the new orings and gasket for it today from Ford. I also drained the coolant from the block tonight. Had to take the starter off to drain the passenger side. Boy a Fumoto valve would be great in lieu of the block plugs.
Here are a few questions for tonight's post:
I have cleaned on the intake manifold but it is really gunked up with carbon. It is a pastey smearry oily gooey (get my drift on the description). I would like to have the intake manifold cleaned/boiled out to get rid of the crap inside. Because it is cast aluminum, can it be boiled out?
I have to be out of town for a few days and thought that I would carry it by a Parts house that washed engine blocks to see if they could do it. Does the stealership boil them out when they do this work? Would it be to my advantage to do this or am I just being wasteful to have this boiled out?
Does anyone have a picture of the ICP sensor or instructions on replacing the sensor?
Here are tonight's work pictures:
View attachment 12814View attachment 12815View attachment 12816View attachment 12817View attachment 12818View attachment 12819View attachment 12820View attachment 12821
