Question Edge CTS Insight Overhead Pod
VinceJE
Spring, TX
I'm adding the Edge Insight CTS and would really prefer the overhead mount, but... I have a sunroof and the stock overhead console appears to be mounted much closer to the windshield than the ones I see pictured on the web without a sunroof. Maybe I'm not seeing it right.
My question is... Do they make an overhead pod that fits given I have a sunroof/different stock overhead console?
:dunno
VinceJE
Spring, TX
Next question... I got the Insight CTS installed (went with the dash pod for now. The diag shows a code for "no reading from the exhaust backpressure sensor". Do all 6.0s have one?
Yes 6.0 trucks have an exhaust backpressure sensor. Mine is on the driver's side head. Look for a sensor at the end of a small metal tube going from the exhaust manifold to the sensor. The 6.0 Bible shows this. Google "6.0 Bible".
79jasper
El Paso, TX
Could be just me, but neither link worked.
Sent from my *******-SM-G890A using Tapatalk
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
Yep mine reads back pressure. Don't know what it should be but at light throttle it seems to run twice of what boost is but drops at cruising speed.
