oi8228oi said:
do you have a link on how do to the mans mod? pm if ya do thanks....
I can describe it real quick if you'd like...
Two ways to do it. The first is to make the EBPV work NORMALLY under all conditions, until you flip a switch to make it come on for braking. This means the PCM still makes it actuate on cold mornings, like it always does.
The second is to completely disable the EBPV so that it ONLY works when you turn it on manually.
Braking effect is pretty darned good. It will hold a 23,500 pound truck and trailer at 60 coming down a 10% grade in 5th gear (direct).
Okay, here goes:
OPTION 1:
Parts list - Two rectifier diodes (like electrical check valves, get them at Radio Shack for 10 cents a piece) for a 12V 20 amp circuit. Wire, switch.
ACTIONS - Find the wire coming out of the EBPV, at the base of the turbo at the front. This wire comes from the PCM. Cut the power wire (the colored one, can't remember what color. The ground is gray or black) and wire ONE of the Recifier diodes into the circuit so that the current can flow ONLY from the PCM to the EBPV. I'll explain why in a minute. Then, take a piece of your new wire, and wire in a recifier to it, then splice to the same power wire to the EBPV you wired the other diode to. The recifiers keep your switch from getting a hot 12V signal when the PCM activates the EBPV, and the PCM from getting hot 12V when you flip on the switch. Now, run the new wire to the switch, and wire the switch to hot, so that when you flipthe switch, it sends hot 12V to the EBPV. Now, your EBPV will function normally, and will also turn on for braking when you flip the switch.
OPTION 2:
Just cut the power wire to the EBPV and leave it cut off from the PCM. make sure you safe up the wire to the PCM so it does not short. Run a hot switched 12V to the EBPV by splicing to the wire you just cut, and voila, instant exhaust brake...
I used Option 1 on my '95, and it worked great. I decided that I hate my EBPV in my 99, so I used OPTION 2 and made it manual only. This has also worked fine.
