Dualmass Flywheel
ryanPSD
Living in Kallynogunforya
No
As far as if your DMFW is going out, you can check for play in the flywheel... with it in neutral (e-brake on), pull the inspection cover at the bottom of the tranny and see how much you can rotate the flywheel side to side by hand.
I can't recall what spec I heard Ford changes it at (maybe 5/8"?) but I had I think over a full inch of play in mine. Not too much noise at idle, but when I shut it down.... huggarackatackaladatackalacktatck-clunk. :nono:
What kinda noise when you let out the clutch? A pop or creaking from the tranny? If it is it is probably the clutch fork (like a $17 part off powerstrokeshop.com)... I went through that myself a while back. -popcorn When I let out the pedal slowly I could sorta feel it in the pedal, it almost felt like a notch it slid/bumped over on the way out. :dunno If you think it's that let me know and I'll dig up my old post from :oops: the dark side. Lots of info in that one.
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
the noise i get is a slight growl kinda hard to describe, i can kinda fell throughout the whole truck.
I have that, it was gettin bad then the other day i shut it off and it was noticlbly LESS:eek: , i had to start it up and shut it off just to know i heard right!
Drove a couple more times and it's slowly coming back now. I'm confused:confused:
Neal
binderman
slacker
sw Iowa
From what I understand if you let the dmf/clutch go too long it puts alot of extra pressureon the bellhousing causing it to break. My truck was like this when i bought it the tranny I found was 1250.00 used but it only had 85000 miles on it. When I tore it apart thdmf was fried.
Ricksofla
