Duallie.....Tire rotation?
Sawboy
Westchester IL
Easy question for you guys that have duallies.
Do you rotate your tires? If so, how?
Assuming these are the tires, I would think this would be the way. But I hear from some guys, they never rotate on a duallie. And yes, I am too lazy and cheap to switch the inners, because of the rim swap needed :D
Now:
1 2
34 56
After rotate:
3 6
14 52
RoyBoy
Diesel Dork
central WI
To do that you'd still need to swap wheels if you have aluminums, as only one side is polished. I don't rotate mine, the rears wear out faster (for some reason :doh: ) I just figure on running through a couple sets of rears per set of fronts :sweet
well, theoretically
1 2
3 4 5 6
should end up
5 4
6 2 1 3
Wood County Tx
i rotate the two fronts with each other
and the rears the pass side set goes to the drivers side
then a week ago i paid to have em broke down and the inner set went up front and the frnts went on the inner rims
Wood County Tx
Is it really worth having them broken down to swap around?
well i figure 40 bux was cheaper than two new front tires at 170 each.
and if i can get anoter 45k out of the "new" front tires i figure i made out ahead
the rears were wearing perfect and flat so the inner rears went up front.
