Driveway drip
missingsc331
new kent virginia
After driving the truck for any amount of time and parking it it leeks about a 1 and a half foot in diameteter puddle of what seems to be antifreeze .. please tell me this is not headgaskets ... i cant tell exactly where its coming from
acjjkamp
Blitz and Harley
Sacramento, Ca
are you sure it's antifreeze?
If you have the A/C on auto, it's condensation run off, which is normal.
missingsc331
new kent virginia
i thought it was just condensation at first also but it seems to be staining the driveway. It seems to be mostly dead center but a little more on the driver side. Thanks
atk
Moderator
simcoe, ontario, canada
maybe you can start by checking all the hose clamps, make sure they are tight and not broken....also would be a good idea to have your coolant system pressure tested(if you lived closer i could help you out there)that way with a constant pressure you could inspect where the coolant is leaking from....from where you said is leaking, could be lower rad hose, rad, water pump, but without actually being there, these are guesses....hope this helps
Dip your finger in the drip stain and taste it, anti-freeze will be bitter-sweet. But I'm thinking with the size puddle you described you would surely notice a drop in coolant level in the de-gas bottle.
02Oilburner
SDD Power Hungry
Raleigh, NC
Im having the same problem. I lose a gallon of collant every 2-3 days if not topped off. Im not over heating so i think the water pump works but it is leaking around the pump could it be the wp gasket? Also how difficult is it to change the wp? When it rains it pours my power sterring is also leaking like crazy. I fill it and drive to store (5 miles) and come home and its empty and is all over the underside of truck. Lucky I have 2 trucks but I want to drive my Diesel my gasser is a wus.
