Driveshaft?
jguzman75
McAllen, Texas
Mission,Texas
I am going to post here because of more activity. Has anyone ever replaced there driveshaft or modified there current to a CV joint out of the transfer case? The lift that I have know has blocks and an add a leaf in the rear, I am using the stock block and the one sent in the kit. When I take off I can feel a small amount of binding and vibration probably because of axel wrap. Will my driveshaft idea correct this or is it better to replace the rear springs?
JamieContouris
Proud to be member #2007
Moyock NC
For every inch of lift you should drop the carrier bearing 1/4 inch. Do not go to a one piece drive shaft either. You will end up cracking the tail shaft case area if you do.
jguzman75
McAllen, Texas
Mission,Texas
Well all Excursions come with a one piece driveshaft. Does that mean I should replace it with a universal joint?
oil_burner
virginia beach, VA
try putting 2 degree shim between the axle perch and factory block, if you still get vibrabration try a 4 degree shim . gotta play with it . i shimed my carrier down 1" and used 2 dgree shims on the axle and now she takes off smooth as butter
TacoCat
