Can you guys help me with this?
I have this grinding, rubbing, scraping noise coming from what i think to be the right front wheel. It seems to happen on every full wheel revalution. Everything checks out to be fine in that area, brakes, wheel bearings ect. I have made my way to the driveshaft thinking ujoints and found that the mid shaft bearing has a lot of play ( a lot of play ) could it be bad or is this normal or am i missing anything on the front end.
07 cc duelly 60k
Thanks
Jeff
07 cc duelly 60k
Thanks
Jeff
