Driveline Vibration
SMOKNZ
Cleveland, WI
I was towing the camper this past week, and was noticed a vibration when not towing. The best way to describe it is it vibrates slghtly between the point where your not accelerating anymore but not decelerating. If you slightly lift off the gas pedal it will vibarate until it is full decel. Could this be the driveshaft or the rearend?
Bill
jopes
Wyoming
sounds like a classic u-joint starting to go out. since they are cheap just replace them all, then see if it goes away.
could also be the center support bearing.
