Question DP Tuner is in...and now some questions
JRJ04
Houston, TX
injectors are in good shape to the best of my knowledge. i tried it this morning and there was no smoke. i let it run for about 5 min this time though. how would i clean the injectors? i run diesel kleen in every tank to keep them clean. i got 123k the clock.
aklim
Hartford, WI USA
I was talking about it smoking when you start it up initially. There is a small puff and after a couple of minutes it clears up unless it is really cold then it looks like there is smoke but probably condensation. This smoke does smell of diesel though. Temps at that time were about 10-20. After 5 mins of warm up, it definitely won't smoke.
Only way to clean injectors is to take them out and have them tested. That is the ONLY way I know for for sure when it comes to diagnosis. DK or any other snake oil is only a SWAG. Kinda like sweeping a hall in the dark. You may have cleaned it but the only way to know is to turn on the light.
Brad1103
