Door Panel Removal
There are two screws (I think) that hold the door panel on. One is behind the reflector and the other is in the arm rest. After removing them, pry out the lower panel using a flat taping knife. Then lift up the door panel and it will come off. It takes longer to type than to do it.
Dave :)
`08 Blue Crew
Somewhere in the lower 48
that is exactly how my `06 door panels came off so I figured no problem.
Doesn't work on this one. First there is no reflector on the door panel and there is no screw behind the door handle.
nc1500
MyFirstPS444
Winston Salem
As signature says, I have a King Ranch CC.
Anyone know how to take the front door panels off?
If you stand back from the door and look at the bottom of the panel there are two cutouts that look like they may be for screw access. The panel may also have those stupid christmas tree clips holding the door to the door frame; hopefully it just slides up like the older models. Sometimes simple is much better.
