I have a 2006 F250 with the regular black door handles but ive seen the color matching ones on other trucks. Do those only come from factory or can they be switched out, or are they covers?
They are handles for the Excursions and the "Sport" model trucks. Depending on your color, (if you have the same that one of those models came in), you should be able to order them from a dealer, or a site like Powerstrokeshop.com.
Ima see if I can find them at my local salvage yard. The thing about painting the stock ones is that it has texture and i want that smooth feel, so i might have to order the chrome ones, sand them, and paint them
It depends on what grit paper you use...take the better part of the texture off, then go to a fine paper. Just keep working down. As long as you don't get after it with a 36 grit...lol. I'd say start at like 180 or so. You'd just have to see what it does.
You would be having to prime them anyway, so you could give them a light wet sand to get rid of the little imperfections before the color is shot.
