DO I DARE
hheynow
Señor Aceite de Soja
Northern California
woofer700 said:
how that the temps are getting down to 34 and lower, do I still run b20?
IMO you are still good to go at 34*F w/ B20. You could add some Stanadyne to the tank. It will lower the gel point up to 40*F, but only works with #2 or #1 or bioD blends (not with B100).
woofer700
Diesel is cool
S/D
22 deg has been the coldest so far, I will be filling with b20 tomorrow. what temp should I start to worry? another question what about filling a portable heater with b20, normally I run #1 all winter, and keep garage at 60 deg, does b20 work the same as #2 (smell) or can I expect a similar burn pattern and alot less smell being the same as #1. I have used kerosene, but like #1 much better running in the heater.
