DIY Propane opinion
rammertide07
Rogersvilles, AL
YouTube - Cheap Homemade Propane Injection System
What are some of your opinions on this set-up and his advice? Anyone tried it? I heard of some guys running propane unloaded running 65+ mph on the interstate to save mpg...is it safe run that speed with no load?
I read on the vids comments about adding a manifold blow off in case a bad detonation??...anyone got any info on that? Also, doing a HOBB switch :)dunno) to monitor the manifold pressure to make sure the truck is under a load before the propane can be injected:confused:
rammertide07
Rogersvilles, AL
your offically a youtuber:lmao
i saw that too, but i havent got a clue good luck:sweet
:watchout.....what does it take for one to be a youtuber? I'm more of a googler (think it was you I helped with the electric fan off a integra using google), thats how I found the vid. So if I'm a googler/youtuber what are you?
Hell no, I'm not doing it till I've done some (let me re-phrase that...A LOT) research on this and find someone that has done it and talked to them. I know the superchips digital injection can tie into the tps and tachometer...and that was my think of the manifold pressure deal, to make sure the engine is under a load. My current project is my own zoo-dad mod. I've never seen it donw the way I'm doing it, but I like it:sly Post pics later
I've been meaning to talk to you...I've actually sent you a pm. Didn't you put the ATS torque converter in your truck?
Messing with the zoodad....Its almsot halfway done. I just did one to see how it worked and I like it. I think theres not enough flow coming through so I'm going to do the other one tomorrow. I drimmiled the side so I could get it in next to the radiator. Debating on to put a filter material around it that I bought from Ace. At 45, my "MPG Display" was saying 25mpg. I drove 45 from Jackson, MS to Starkville, MS on the natchez trace and the best I seen was 21.8mpg....not a bad increase. I drove out to town with speed limits ranging from 45 to 60 with plenty of redlights and got 19.2mpg in that 36mi run.
here's my opinion of piggy-back propane systems...
you save money on one fuel, but burn it up on another fuel..
do you really come out money ahead?
propane is in the high $3.somethings a gallon right now...
wpfd571
White Pigeon Mi.
I also think anything you gain in mpg would be offset buy the cost of the propane, I think if your doing it to save money its gonna take a long time to get your investment back and break even
rammertide07
Rogersvilles, AL
I figured it up before from other people's numbers and they didn't come out ahead...and I'm fine with that. I think it would be nice to have to have extra pulling power and still lower your egt's. Do ya'll have an opinion or advice about the set-up itself?
I've seen that video too JL, but because of their lack of english I really didn't get an understanding of what they was doing.
6.0PSD777
Mass
A kid i know blew up his motor in his 97 using propane, however idk how he had it set up
