display code
the cable guy
ct
2006 6.0 stock
sitting in the drive thru a few days ago, in 4x4 high. went to move ahead and I heard a ding ding. WTF, where the odometer usually shows the milage I see TCB or TBC not sure. only lasted a few seconds then disappeared.
NO CEL and no codes when I plugged it in.
any thoughts?
fordoor
SDD Member
N. Calif.
2006 6.0 stock
any thoughts?
Very strange indeed. The only thing I can think of is that you've reached the Time to Count you're Blessings mileage. :D I look forward to hearing what the heck it really means.
6.0PSD777
Mass
05 and up factory brake controller is an option - comes with the intergrated controller and different brake booster. if you install the controller in a truck that didn't have it from the factory it you will get that code on the dash without dealer programming.
6.0PSD777
Mass
Must have glitched for a min or something - wouldn't worry too much about it.
the cable guy
ct
thanks for the input guys, there is nothing I can do about right now. I hope it was just a glitch.
Northeast Texas
i will go out on a limb
go check the fuse for the tbc and auto a/c system. It likes to wiggle and get looses enough to cause things to go BUMP
if the a/c fuse popps or wiggles it will cause a tbc fault and vice versa
