Question Differential temps
VinceJE
Spring, TX
Anyone know what the normal temperature range should be for the front & rear differentials? What would be considered too hot?
They have a tendency to run warm especially when loaded, your oil (gear lube in this case) will begin to break down when you start to approach 300 degrees. I would guess your diffs could easily be running 225-240+ easily though.
scottu5
