roosterdiesel
Earl needs B100
I had read somewhere that adding cetane retards timing but not positive,someone please chime in with correction.
Higher cetane doesn't retard timing, the only thing that can do that is programming. Fuel with higher cetane takes more heat and compression to combust. So lower cetane fuel combusts sooner but that's not "advanced timing" so to speak.
As for the comment on premium gasoline, some vehicles have higher compression ratios and need the higher octane so they don't have detonation problems also known as pinging. A gas engine that pings is having peak cylinder pressures while the piston is still on it's way UP, that is a loss in power and mileage. Today's advanced gas engines have knock sensors that tell the computer to pull timing when detonation occurs. When that happens the engine is not at full efficiency.
I will always pay more for BD.
