Question diesel in radiator
zudnik
sauquoit/NY
I have an 02 f-250 7.3 diesel and have been getting what smells like diesel fuel in my radiators overflow tank and eventually overflows thru the weep hole, and seems to take a lot longer then normal to reach operating temp., 20 min. or better any ideas whats going on???:(
on a 7.3, that's usually a sign of a cracked injector cup
the long warm-up time probably isn't tied to it, unless the hydrocarbons have degraded/damaged the thermostat..
zudnik
sauquoit/NY
so is that a major fix or not bad, do it yourself fix or have a pro do it??? truck has 112,000 miles so thermostat may be bad also. Thanx for the help!!
You will want to look closely at the water pump. Mine died at 122,000 miles on my IDI 7.3.
Injector cups to some are a DIY Job but to most it is a mechanic's job. Depending on which one is leaking it is possible (though not easy) to do it without pulling the head(s), most who DIY will pull the heads and take it to a shop to have the heads refreshed and new injector cups at the same time.
silverF250
Arnold, Mo
To DIY the injector cups you need to know someone with the tool to do it or know someone who will rent you the tool. The tool is very expensive to buy for one time use. If you do plan on doing it you better figure on getting new o-rings for the injectors some will undoubtedly be bad. I don't know if any of the site sponsors will loan you a tool or not but Swamps diesel will rent one to you.
It's a relatively easy process just make sure you follow all the steps you do when pulling the injectors.
zudnik
sauquoit/NY
thanx for the input, has been very helpful. have also been told it could be a cracked head, hopefully this isn't the case. will probably try and find a shop to do the work, if its not too expensive, as i'm not really familiar with diesel engines. will let ya know how it all goes. :)
zudnik
sauquoit/NY
ive heard this too, but first will try and get the diesel out of the coolant, then will change thermostat ( diesel site has one, 203 deg stat) and will probably do water pump then , before it dies. thanx for the heads up!!
