DIES AT SLOW TAKE OFF
DSR
USA
fighting problem with 1996 f-250 dies at slow take off if floored works good i hooked up scan tool no codes changed cmp no luck. will die if reved up in N at let up to come back to idle.
DSR
USA
DIES AT TAKE OFF
yes its still hooked up dont now if it works i looked onscan tool at exhaust psi found shows 53 for exhaust psi
fordtrucker4life!
I work with waste
SE Michigan
I wonder if it is sucking the fuel dry and keeping it revved up lets it pump fuel. 3208 cat's do this and an injector pump rebuild needed to be done.
DSR
USA
DIES
i thought of that but it dies right off idle just as start moveing . starts right back up. will take off ok if powerbrake a little just to bring rpm up
DSR
USA
found problem
nut on back off ipr fell off solnoid held on by wires and moveing around
