rsjohnsn
Ok guys, help me diagnose a problem. I have been having this issue for a while now and I had written it off as needing a reflash. The issue is the engine missing at startup and lasting until the engine warmed up. I was told to get the latest reflash that did something to the injectors in that it heated the injectors or something like that. Anyway, I had the reflash done but nothing had changed. I am now experiencing longer times even after warm up before the engine settles down. After the engine warms up she does fine. She use to settle down at exactly the first line after the C on the temp gauge and now she last until the gauge reaches normal. What do I look for? Anyone have this problem before? Oh yeah, I had the sensor replaced that sets behind/under the turbo that regulates the pressure of the injector oil (ICP IPR?) I ran the truck for a while with this sensor leaking before I knew what it was, could this have hurt something?
Thanks
Scott
Thanks
Scott
