defeuling from over boost
jopes
Wyoming
I installed one of the Boost pressure releif valves on friday, and the SES light still comes on when the boost hits 25 psi. by time the guage hits 27 psi it is defeuling and it drops and holds @ 25 psi.
IT does it in every gear, but OD. once in OD I can get 30 psi, but the SES light still comes on it does not drop boost in OD.
First thing I checked to make sure the clown who installed it did so correctly. ;)
jopes
Wyoming
why am I loosing boost then in the lower gears when it goes over 25 psi?
roosterdiesel
Earl needs B100
Amarillo,TX
Who's BPRV? You may try spraying some WD40 on it. Some of them tend to stick sometimes, but that's usually when it's cold.
If it's the 1211 ICP code boost won't drop like a rock.
jopes
Wyoming
dieselsite.com. I thought it might have been sticking and it said in the directions to use some wd40 on it. I had already tried that as well.
roosterdiesel
Earl needs B100
Amarillo,TX
Is it the BRV+? If it is, have you tried connecting your gauge to the MAP side and see what it's reading?
jopes
Wyoming
yes it is the plus. I will have yet to try that. Maybe tommarrow depending on when I get home from work.
Ricksofla
