bears4x4
grease monkey
very true, truck looks good
One other thought on the sanding of the bumper; when you get it all sanded, move it to the final place where you will spray it. Wipe it down with acetone and DO NOT TOUCH IT AGAIN until it is painted! You will leave oils and sweat from your fingers, no matter how clean your hands are. This will affect the paint job down the road. You will get metal rust from underneath the paint.
I used a real fine sandpaper (like a watersand paper) to knock off the shiney of the chrome.
After sanding, I used acetone to clean them up (takes off oils/wax)
I sprayed no telling how many coats of base & clear. I will probably redo them before long. The clear I used is just not shiney enough, and I don't think I let them dry long enough. The next day, you could see where all the bugs have indented into the paint.
