dash vents not working
SMOKNZ
Cleveland, WI
OK guys, try this to fix the problem, I went to unhook the vacuum line from the pump (facing the fender) the pump came apart and started working, It is o-ring sealed so it will be fine, maybe you guys will have the same luck......
Not sure I am following here, you went to unhook the line and the pump came apart? You mean you took it apart? Was there some crap inside?
Bill
rotorholic
Dallas TX
came apart.....
Bill
NO, it came apart, the pumps are o-ring sealed, Me pulling on the hose from the top was enough to make it come apart....
