Dana 60 is in!!!
96P_Stroke4x4
philadelphia, pa
i wasn't even thinking about it at the time. since i made the trip up there i think joe should deliver a set to me hehe but like i said before, the badges might all be coming off anyway.
94f450sd
certified nutjob
plymouth,ma
well if you want a set and one of you is going going here or there let me know.ill get a set and send with shorty if he goes down there,or ill meet up with you if you make a trip up here again.that is of course if you dont get a set by then.
was everything OK with the axle?
96P_Stroke4x4
philadelphia, pa
i'll let you know about the badges. everything went well except for not having holes for the sway bar brackets in the frame and not clearing out the bolt holes in the yolk before installing it. other than that there was some play in the inner tie rod from the pitman arm where it connects to the steering cross ling, so i'm gonna replace that with new anyway.
Brad1103
