Hey Dave,
Went to the stealership today to get the Speed Control Deactivation Switch and he had the switch that goes on the end of the Master Cylinder but when he pulled it up in the system he said there were two switches listed but he could not tell me where the second switch was located. He printed the schematic out and said that he thought there was a switch under the steering column that might be what it was referring to but he did not have one in stock. Any Ideas????????????
yep its on the upper brake pedal arm,
some were to sensitive and would cause the cruise to cut off on bumpy highways
then the switch they put in was to some, to hard to trip
my 06 if you hit the pedal from the side with a good snap of the foot it would drop off
but if you tapped it on the edge like you were stopping it would not always cut off, but instead do like yours , speed right back up.
the steering switch is probably the easiest to shut it off with our jamming the brakes
if its any consolation the 150 i have now is just as bad, IMO i have to depress the brake to much to cut it off, and this truck has very very sensitive brakes, they stop you in short order.
