Smoky
My son moved the truck today from out of my garage to wash it so he pulled it into the driveway. It will not run now. It cranks over and sounds like when a gas burner wants to fire but just will not catch and run. Ive plugged it in for the last 4 hours and just tried again. Same thing.
When I first started it after it was washed, it bucked like it was supercold. I have no way of pulling codes out of it right now. I just did alot of work on includings having the FICM repaired with Atlas 40 put on it. I put in a blue spring as well. I put the FICM back in last Tuesday night and installed the blue springs. Charged the batteries all night to insure a good charge as both batteries were taken out and load tested to see if the batteries were good. They were good under an individual load test.
Wednesday morning it cranked over and fired off first thing without being plugged in. I drove it about 150 miles and the only thing that seemed wrong was that when i accelerated hard after about 15 minutes on the road, the tow/haul light started flashing and I had to pull over kill the truck. It started back up fine and drove on another 120 miles that day.
Then today all crank and no run.
Any Ideas??????
Any Ideas??????
