Cracked transmission case?
orion_134
Woodbridge, VA
I noticed a vibration that got exponentially worse over a day and put it on the lift and the bellhousing is cracked from about the 10 o'clock to 6 o'clock position...fun fun...now, what caused it? I am going to get a used transmission rebuilt by a local shop and hopefully that will last me another 200k, I just want to know if it was an imbalance that caused it or a bearing...the temps never got over 170 since I installed the converter, cooler, vb, and gauge 12k ago...but they most likely did before that. I will be checking the flexplate when I pull the trans.
Whaday'all think?
Jesse
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Has the tranny been removed before to your knowledge?
I know if not done right, a tranny bell housing can crack if bolts are tightened before the bell housing is tight & flush to the motor. Just ask my son. :doh: :doh:
:doh: D'OH! :doh:
anyway, this is what I'd be looking at also
orion_134
Woodbridge, VA
The trans was removed 12k ago and has been running fine up to yesterday. Will the vans have the same trans? Any gas engines? Pre-99 weren't 4r100, they were e4od right?
Driveshaft imbalance...I replaced all u-joints, front flange, and the u-joint "barrel" that holds two of them 10k ago, should it have been rebalanced?
Thanks,
Jesse
Thanks,
Jesse
I would have, because it's cheap insurance.. around here, they get like $35.
well, now that I'm coherent...
I've seen them break bolt ears or tabs off around the alignment dowels as TailGunner suggested, the last one I saw bust in half down the middle was due to, oh how am I gonna put this; "High torsional loads" in a drag car...
might want to put a fresh set of mounts (both engine & rear trans) on it when you put the new unit in..
do your downpipe while you have the trans out, also
orion_134
Woodbridge, VA
Do my downpipe? I have a 4" downpipe in it. It didn't break the ears or dowels, it's about 8" from the mounting surface of the trans to the engine. I will inspect more once I pull it and keep y'all updated. For now, I really need to know which year/model vehicles have the same trans so I can call around the local yards. I thought the 96+ Powerstroke (van or truck) all had the 4r100?
Jesse
trackspeeder
Stone Crusher
North Branford CT
You need a 4R100 99 and up. Diesel only. It can come from a truck or a van.
Gas version will not work
Anything before 99 is the E4OD. This will not work.
Brad1103
