runnindiesel
yeppers....
ive replaced mine once on the side of the highway at about 122000
Mobeydick said:Of the 12 people I personlly Know that have a 99/01 Superduty with a 7.3 I know of none including myself that has HAD to replace the CPS. I did replace the CPS on my 01 but I did that because of web sites like this that people tell you they are all bad. My truck was missing I was told the CPS Could be causing this. It was not, the OEM CPS is on the shelf along with a TPS, Speed Sensor and a Vacume Pump All good parts I've take off and replaced because of what people tell you on this and other sites!!
Anything that shuts down any motor on a Steep Mountian Road is Deadly!! Including running out of fuel!!
Hoss 350 said:There have been far too many people having trouble with CPS to just state that you have not had any and then just dismiss the issue as if it does not exist. Lucky you. Now, realize that many of us have had troubles, and many of us feel that the issue is so prevalent that it should have been solved long ago.
There was a guy called J_apeterson on TDS that felt the same way you do. Simply because you have not had the problem, it does not exist. Wake up. This is a pretty silly way to look at the world...
Oh, and BTW, all of this "advice" that you got that was so bad was just people trying to help. You made the decision to act upon that and change out perfectly good parts. Don't blame the people nice enough to take the time to help you out, without any promise of payment or otherwise. We are here to help. if you don't want to listen, don't. If you do, then don't complain when you get bad advice.
Mobeydick said:All I’m saying is take Advice on these sites with a grain of Salt!!
Mobeydick said:Where Have I Complained
Mobeydick said:I never said I didn't appreciate the Advice.
Mobeydick said:BTW: A Web Site did give me the answer to the miss. The Dieselmans Site!! I didn't know there was a Dieselmans site until I was just about to sell the truck!!
whatabudro said:Nobody on this site is charging for their opinion. If you took the advice of an "internet expert" to save yourself a buck, then the decision to change your cps with a missing engine was your decision. Maybe you should have done more research.
Mobetdick said:As far as what was wrong with mine. I was running the wrong type of oil in truck. It was a very good Diesel rated oil but not a CI-4 rated!!
Mobeydick said:It was not, the OEM CPS is on the shelf
whatabudro said:Take some of the best advice I can offer you and put it in the glove box.
Bryan
