Couple questions
Fireman
Resident Of Hicktown
ohio
Hey folks,
Ok here goes. Awhile back I had my clock spring replaced to gain use of my horn again. I was told that would also bring back my cruise control. Now when I attempt to turn cruise on, nothing happens. When I turn it off, the dash lights go out for a min then come back on. Also the horn honks too.
Anyone know of an easy way to fix a windshield sprayer that doesnt work? Passenger side does, but not drivers. Is it simple as replacing hose that is fed to nozzel? Thanks everyone an have a safe day!
RSG
Savoy IL
my cruise wire had the insulation rubbed off where it went over a hard part and I resoldered and insulated it. It was blowing a fuse everytime I turned the wheel and it took out the cluster iirc.
Let me know what you figure out with that sprayer problem -- I've always been unhappy with my drivers side...
JRNOLL
Bakersfield, Calif.
I had a plug on my drivers side spray nozzle , I used the smallest welding tip cleaner that would go in the passengers side sprayer and not ream, to clean out the plug.
Fireman
ohio
where do i look for that wire at? haha im no mechanic but i'll give it a whirl.
