Cooling Fans Question
What kind of voltage do computer cooling fans run on? I have read about installing low draw fans in my camper to prevent water line freezing but I am not so sure they come in 12V. Do they?
keanoknick
Big Stroker
Cowtown TEXAS
A computer power supply usually only provides 5v and 12v (there are exceptions)
You should be able to get 12v fans pretty easily from a computer supply place, or radioshack:sweet
Wood County Tx
crumm
i bought about 8 from radio shack last year to use for the movement of air in the rv to help with cooling things and air flow to prevent condensation
work great.
cost about 10 a piece
dpantazis
#12
under the cheddar curtain
crumm-
don;t neglect the case fans, they are 120V too.
12V-depends on the vintage and quality. iirc they are somewhere about 8-10 watts each. so at 12V, that is about .75-1A. that wattage i remember from having to do heat loads calcs once, so its propably pretty conservative and actual draw is way less.
dp
