HowieE
Last weekend while towing I noticed my coolant temperatures could reach 220 degrees before the clutch fan cut in. I was not impressed to see 220 and far less impressed to see the fan not cut in until 220.
What temperatures are you seeing under load? Can I run a lower thermostat? Can I adjust the cut in point on the fan? What is a normal temperature?
There is 45,000 miles on the truck. Could the radiator be clogged inside or out?
The lowest temperature of the coolant was 195 after going down a long hill.
